Curious if anyone knows.
Noticed my old 2000 2WD V6 Tundra sat about 1" lower than my 2003 V8 Tundra.
Going by the rear bed heights. Both where 1/2 ton trucks
What was the difference. Weaker springs? Or different leaf spring shackle?
Only thing I could think of is the 2wd would have had to have stronger springs. So it did not go down as much with a 1/2 ton load.
But if anything the 2wd seemed to ride better with no load.
4WD's usually sit higher for better ground clearance. Guessing probably a selling feature for those that may want to go off road but not sure where they get the extra ride height. Technically the 2WD would probably have a better payload capacity. Both might be 1/2 ton trucks but the more stuff they put on a truck the less overall load it can carry. Like if a 2WD regular cab is say 200lbs lighter than a 4WD extended cab then it should be able to carry an extra 200lbs.
My thinking was the 2wd should have less payload. Since the clearance between the frame and the axle would be less.
Payload and clearance are not one and the same. If you still have your owners manual have a look at the payload section and you will see the amount of weight a truck can carry goes down as the options go up. So something like a 2WD reg cab can carry more weight than a 4WD double cab because the double cab weighs more.
