3" lift
1769 Views 8 Replies 8 Participants Last post by  NoKz
I'm looking at putting a 3" lift on my 04 double cab and I was woundering if I would be able to fit 305-55-20's on my truck?
Thanks Guys
Scottie
1 - 9 of 9 Posts
max you can run is a 33" tire. Im not sure what standard size those tires you want are. Too lazy to calculate.
the guys at extreme truck toys where i got mine told me to run 35's and there would only be minimal rubbing, just to keep them narrow.
285/75/16's, 35's are not going to fit.
33 yes. 35 NO WAY. Not with only a 3 inch lift.
A 285-75-16 BARELY clears. It's overall diameter is 32.8. The 305-55-20 is 33.2 which is a difference of .4. Factor in only half the tire rubs so a .2 difference (Per side of the tire) and it may clear. Do at your own risk but I think it will clear with some minor trimming like removing the mud flaps and may be even need a swing or 2 of the hammer on the pinch welds. I would try it
I'd like some of what they are smoking! I rub the **** out of my 33's when i come off a jump. A 35 would stop spinning in the wheel well. ha ha ha
hell no on the 35s i had to trim with the 5in...
5 inch can be done, recommended for 6 inch. 3", absolutely not. Max is 33's.
I'm running 285/75/R16's and they rub on the frame at full turn.
1 - 9 of 9 Posts
