so im looking to lift my 09 DC tundra right now im sitting with bilsteins all around, top settings in the front. im planning on getting the CST 3.5 lift spindles and that would put me up around 5" total up front and im curious as to what the best method to raise the rear would be and what all i would need to take into consideration before going ahead with the instal, like new brake lines, and things of that nature that could be easily overlooked.
so up front ill have the bilstein 5100s on top setting roughly 1 1/2 to 2 inches, and then the CST lift spindles witch advertise true 3.5 inches up front so 4 to 5 inches total.
and in the rear im not sure weather to go with a combo of things like shackles, AALs, or blocks.
it sits completely level right now so i would need about 3.5 in the rear also to keep it level or with very minor rake.
i have also got plans to get a carrier bearing drop bracket, and new UCAs.
i just want to make sure i do it right the first time i like to do my own work, makes it feel more like "my truck" if you know what i mean.
im open for any suggestions from all you guys that have lifted you trucks and im verly thankful for ay help.
