Just changed oil in my new 07 Rav 4cyl. Manual says it takes 4.5 qts. with filter change. That is what I put in but appears to be .5qts. over full. Any ideas
Does your owners manual say 4.5 qts? Where did you get the idea it's 4.5?
Mine says 4 qts w/ filter. Mine is '05 but same motor - i dont think they changed the sump capacity.
- grumpy
Just go by your manual - it will list both engines - pick the correct one. Maybe if you cant do this you shouldnt be working on the pig! I would take ANYTHING you read on a forum as anecdotal ...
You just may have racked up 1- =vote for the 2007 Automotive Darwin Awards:devil:
Hey Guys--you are not a lot of help. As I stated in my thread the owners manual says 4.5qts. not litres with filter change on my 2007. Anyone have an 07 that can shed some light.
Grumpy don't waste my time with your pathetic responses.:ts:
Recall that you have to drain the oil out before you put the new oil in. Many dealers get this step wrong:devil:
Geo - can you scan and post the capacity table in the 2007 Toyota manual so we can determine if you're missing something. OTW, Call toyota - forum help is spotty at best and malicious at worst. I'm so glad you like my brand of help.
My 06 owner's manual did say 4.5 qts. I just changed the oil and put 4.5 qts in and it also is over the full mark. Strange. 4.3 seemed to be closer to correct.
