REPLACEMENT
CAUTION:
- Prolonged and repeated contact with engine oil will result in the removal of natural oils from the skin, leading to dryness, irritation and dermatitis. In addition, used engine oil contains potentially harmful contaminants which may cause skin cancer.
- Precautions should be taken when replacing engine oil to minimize the risk of your skin making contact with used engine oil. Protective clothing and gloves that cannot be penetrated by oil should be worn. The skin should be washed with soap and water, or use waterless hand cleaner, to remove any used engine oil thoroughly. Do not use gasoline, thinners, or solvents.
- In order to protect the environment, used oil and used oil filters must be disposed of at designated disposal sites.
<A name=RM000002O1G004X_02 xmlns=""><A name=RM000002O1G004X_02_0002 xmlns="">1. DRAIN ENGINE OIL
(a) Remove the oil filler cap.
(b) Remove the oil pan drain plug and gasket, and drain the engine oil into a container.
(c) Install a new gasket and the oil pan drain plug.
Torque: 40 N·m (408 kgf·cm, 30 ft·lbf)
<A name=RM000002O1G004X_02_0003 xmlns="">2. REMOVE NO. 1 ENGINE UNDER COVER
(a) Remove the 3 screws and 5 bolts.
(b) Unhook the engine under cover from the vehicle body as shown in the illustration.
<A name=RM000002O1G004X_02_0004 xmlns="">3. REMOVE OIL FILTER ELEMENT
(a) Connect a hose with an inside diameter of 15 mm (0.591 in.) to the pipe.
(b) Remove the oil filter drain plug.
(c) Install the pipe to the oil filter cap.
NOTICE:
If the O-ring is removed with the drain plug, install the O-ring together with the pipe.
HINT:
Use a container to catch the draining oil.
(d) Check that oil is drained from the oil filter. Then disconnect the pipe and remove the O-ring, as shown in the illustration.
(e) Using SST, remove the oil filter cap.
SST: 09228-06501
NOTICE:
Do not remove the oil filter bracket clip.
(f) Remove the oil filter element and O-ring from the oil filter cap.
NOTICE:
Be sure to remove the O-ring for the cap by hand, without using any tools, to prevent damage to the cap's O-ring groove.
<A name=RM000002O1G004X_02_0005 xmlns="">
4. INSTALL OIL FILTER ELEMENT
(a) Clean the inside of the oil filter cap, its threads and its O-ring groove.
(b) Apply a small amount of engine oil to a new O-ring and install it to the oil filter cap.
(c) Set a new oil filter element to the oil filter cap.
(d) Remove any dirt or foreign matter from the installation surface of the engine.
(e) Apply a small amount of engine oil to the O-ring again and temporarily install the oil filter cap.
(f) Using SST, tighten the oil filter cap.
SST: 09228-06501
Torque: 25 N·m (255 kgf·cm, 18 ft·lbf)
NOTICE:
- When tightening the oil filter cap, do not remove the oil filter bracket clip.
- Make sure that the oil filter is installed securely as shown in the illustration.
- Be careful that the O-ring does not get caught between any surrounding parts.
(g) Apply a small amount of engine oil to a new drain plug O-ring, and install it to the oil filter cap.
NOTICE:
Before installing the O-ring, remove any dirt or foreign matter from the installation surface of the oil filter cap.
(h) Install the oil filter drain plug.
Torque: 13 N·m (127 kgf·cm, 9 ft·lbf)
NOTICE:
<A name=RM000002O1G004X_02_0006 xmlns="">5. ADD ENGINE OIL
(a) Add fresh oil.
Standard oil grade:
Oil Grade
Oil Viscosity (SAE)
ILSAC multigrade engine oil
0W-20
5W-20
(0W-20 is best choice for fuel economy and good starting in cold weather.)
Standard oil capacity:
Item
Specified Condition
Drain and refill with oil filter change
7.0 liters (7.4 US qts, 6.2 Imp. qts)
Drain and refill without oil filter change
6.6 liters (7.0 US qts, 5.8 Imp. qts)
Dry fill
8.4 liters (8.9 US qts, 7.4 Imp. qts)
(b) Install the oil filler cap.
<A name=RM000002O1G004X_02_0010 xmlns="">6. INSPECT FOR OIL LEAK
(a) Start the engine. Make sure that there are no oil leaks from the area that was worked on.
<A name=RM000002O1G004X_02_0011 xmlns="">7. INSPECT ENGINE OIL LEVEL <A href="http://tis.toyota.com/t3Portal/document/rm/RM04E0U/xhtml/RM000002MQJ005X.html#RM000002MQJ005X_01_0001">
8. INSTALL NO. 1 ENGINE UNDER COVER
(a) Hook the engine under cover to the vehicle body as shown in the illustration.
(b) Install the 3 screws and 5 bolts.
Torque: 29 N·m (296 kgf·cm, 21 ft·lbf)
Torque: 5.4 N·m (55 kgf·cm, 48 in·lbf)
