Anybody out there have a 5th wheel hitch installed on the
07 tundra yet. Any difficulty in doing this. Is there a kit for the
frame for a hitch?
I don't know whether or not it's "OK", but I've towed 10,000 plus quite a bit with my 4X4 and I've not had any problems myself. . .is it ok to put 5th wheel hitch in 07 2wd tundra limited trd & haul 32 ft 11000 lb. trailer ?
is it ok to put 5th wheel hitch in 07 2wd tundra limited trd & haul 32 ft 11000 lb. trailer ?[/QUOTE
Is it 11,000 pounds before or after it's loaded?
Either way, you are over the capacity. I'm sure you will get varied opinions.
Exactly. The yahoos will say go for 20,000 lbs, you'll be fine, the WP will say don't exceed 80% of rating.Is it 11,000 pounds before or after it's loaded?
