ok jk, its only at 6/6 right now, ill be notching the frame monday and tossing some 2.5" blocks in. Thought you guys may wanna see what it loos like now.
They look like the Boss 330's. Looks like he had them powdercoated/painted black even though they come in a gloss black. I like this look mucho better!Cool, what wheels are those?
Cool! And perfect size!Yea boss wheels I had powdercoated satin black, 295/35/24"s
It does look good but I agree it will look better without the gap in the back.I dont rub on the fender, but i do run on the inner liner when i take turns any harder than a grandma would. So Im yanking the liners also and ill see how it is after that. And I wouldnt mind keeping the rake, but im not a fan of wheel well gap on a lowered vehicle
I thought an even stance distributes the weight evenly... resulting in more weight in the rear...more traction...and I forgot to mention with the rake you'll also get better traction, especially when supercharged.
That's crazy Marky Mark. I guess it would be most noticable if your tires were exactly even with the wheel well because that tire would stick out....Also FYI..Check your passenger side rear wheel..It sticks out further than the drivers side rear on our Tundras. With aftermarket wheels its very noticeable as it comes out a weeee bit past the fender well. No one has yet to state as why this is. So you might end up bottoming on top of it unless the regular cab is different than the DC and CM cabs. Let us know.
Yeppers..That is one of the reason I had to have my rear axles shortened for my AirRide setup so the wheels would tuck.That's crazy Marky Mark. I guess it would be most noticable if your tires were exactly even with the wheel well because that tire would stick out....
