I need your help and opinion. I don’t mind doing modifications on my 2007 Tundra 4x4 5.7L DC to achieve the intended results of the tires sticking out minimum 2”-maximum 3”. I just need to know what mod’s I need to watch out for, so I can make an informed decision. These are the final questions I have before purchasing. Post pics so I can see what you have done. Thanks everyone, Jeff.
18” wheel Setup 1: 6” Pro comp stage 2
37x12.50x18 BFG’s MT
Wheel Options:
XD Monsters 778, 18x9 5.71 backspacing 18 offset
XD Monsters 778, 18x9 6.38 backspacing 35 offset
XD Hoss 795, 18x9 6.18 backspacing 30 offset
Notes:
I like a bigger side wall, hence the 18” wheel/tire combo.
I want the tires to stick out the sides 2-3”
18” wheel Setup 2: 6” Pro comp stage 2
37x13.50x18 Toyo MT
Wheel Options:
Questions:
Which combo will achieve the tires sticking out 2-3”?
Both tires accept 8-10 inch wheels. Will the side walls look like a balloon?
20” wheel Setup 3: 6” Pro comp stage 2
37x13.50x20 Toyo MT OR 37x12.50x20 BFG’s MT
Wheel Option:
XD Monsters 778, 20x10 5.03 backspacing -12 offset
XD Hoss 795, 20x9 6.18 backspacing 30 offset
Question: How far will tires stick out on the sides, rub? I am ok with mod’s to fit tires. What mod’s are they?
How will the tires look with the 12.50 on a 10” wide rim? Balloon look?
Should I just stay with the 13.50 on a 10” wide rim?
Wheel Options:
Notes:
37x13.50x18 Toyo MT
Wheel Options:
Questions:
Wheel Option:
