Hello All Am A New Guy ...Question I Have Is After Driving Around During Hot Weather....When I Turn Off My Truck And Then Restart It ...While The Engine Temp Is Still Normal ....My Truck Has A Hard Time Starting After About 3-5 Sec....Starts Fine In Cold Weather ....Any Help Would Be Appreciated.
You need to check the following:1) Air filter2) Fuel tank vent clogged3) Bad engine ground connection4)Defective pick-up coil in the distribution5) Check the ECU with a scanner for faultsPost the solution when you find it.
