I just bought new spark plugs from the Toyota dealer (Good one's/not cheap) and went to put them in and I don't see the spark plugs anywhere, a few plug wires that go towards the firewall and I loose them. Is there a web site that shows where they are located so that I don't waste unneccasary time?
Thanks, D
On the 1mz-fe engine there are 3 plugs up front and 3 behind (under) the intake manifold. If you reach around you will feel the three ignition coils (square top) there will be 3 10mm bolts (one on each coil). Once you undo the bolts you will have to pull the coils up and out. Then you will be able to use an extension and spark plug socket to get out plugs. They will look like the image attached (see three in front).
