I have an 03' tundra 4x4 and just picked up a set of racerunner coilovers for the 96' - 04' tacoma because of a good deal. So first off these will bolt in no problem i am assuming, correct? are the coil springs the same on the tacoma as they are on the tundra?
Is the only difference between the tacoma shocks and tundra shocks just the valving? and if so will It be a big noticeable difference that I should get it revalved?
what should I put the collar/lift height at so It wont be to stiff eliminating travel and wont get spring slap?
thanks for the help
Paul
thanks for the help
Paul
