1 - 10 of 10 Posts
First, how does my oil look? Is that what it supposed to look like, or is there an indication of anything be wrong?
Second, when I loosened the fill cap it hissed like a beer can opening. Is that normal? I thought there was a breather to keep pressure from building up?
Third, anyone know off hand what the torque specs are for the two plugs? Or is it in the manual?
Moderator
Should not be any pressure. Have you done the breather modification? I recommend it very highly. Cheap and easy to do and have not had a single seal failure since.
Here is a picture of my first differential change after purchasing the truck used.
Moderator
Based on what can be seen in the pic, the diff oil looks fine. How many miles on it?
If you had pressurization that manifested itself by hissing when removing one of the plugs, then your breather is clogged. You must remove/clean/replace the assembly immediately. Too much pressure (caused by heat) will stress your axle seals and may blow through and leak.
Torque specs are 39 ft/lbs for both plugs.
Discussion Starter #4
Damn. What are the chances of the dealership having the breather assembly in stock so I can just swap them out?
62k and change and the first diff oil change on this truck.
Moderator
Do the breather mod - has to be less expensive than buying an OEM breather from the dealer. Much better to have the breather run through a tube up behind the taillight lens as it keeps it from getting clogged.
Are you sure the hiss was from built up psi? The first time I removed the fill plug on my diff, I heard a hissing noise. I removed the breather and it was OK. After some further research on here, I found the hiss I heard was actually air being sucked into the diff rather than blowing out. The cooling diff lube had created a vacuum and the breather has a one-way check valve to relieve psi with no way to compensate for the vacuum. The neg. psi was equalized when the diff plug was removed, causing the hiss.
Discussion Starter #7
I suppose it could have been a vacuum... what would be the easiest way to figure out which way the air was moving?
Moderator
Drive it around and get the diff nice and hot. Then, jack the rear up slightly, tape a small strip of paper so it hangs over the fill plug, and remove the plug slowly. Watch the paper. If it's heat pressurization, the paper strip will blow out.
Does anyone know the max acceptable pressure for the axle seals? The valving pressure in the breather?
Maybe he had a snake in there...:)
IIRC, the breather just has a steel ball in it (like a BB) with no spring. The pressure required to unseat it would be minimal while any outside pressure - water, etc. - would push it down and seal the diff. Not sure about the axle seal psi.
1 - 10 of 10 Posts
