1 - 7 of 7 Posts
I am getting ready to give my truck a much needed detailing and I was wondering.....if I am planning on using a compound with my Porter Cable, do I still need to hit it with the clay beforehand? Doesn't the compound pretty much accomplish the same thing?
Thanks.
It probably does, but there could be deeper embedded contaminates that compound will not remove.
It only takes 10min, just go ahead and compound. :)
Clay, Yes, Compound, NO. I was in the Detailing business for decades and my father still owns a lartge detail shop. Claying removes surface contaminates which makes for a better surface. only compound if you need it, Dullness in the paint or scratches. Use a good quality cleaner wax or a Polish then a sealant to do your paint.
Compounding, when needed is fine. It is not something to shy away from if it is needed.
Discussion Starter #6
I have a natural white Tundra which, from what I have read, does not have a clear coat. My paint is in fairly good shape but it is starting to look a little dull and chalky in certain light conditions. Also, I have some set in hard water spots (FL water sucks).
Given that my paint does not have a clear coat, should I be concerned about using clay, compound and polish and removing too much paint?
Thanks.
Your truck is painted with Imron iirc. It is hard as a rock and you should have no worries using any modern car clay/compound/polish or anything else on the truck.
Even if you were to take a rotary buffer and the heaviest cut compound/buffing pad, you could still compound a car 4-5 times over its life and leave healthy paint. What you will be using will not even come close to the cut of a heavy compound, so you will be fine.
1 - 7 of 7 Posts
