I was wondering if any one else had the 'access door release' remain in the shut(closed) position after the driver or passenger side door is open? The first time this happened, I had not realized the latch remained closed, I could not get the access door open. Once you push the latch in a little farther the latch would only then release. This had happened a couple of times, mostly when the cold and the vehicle sits for a few days. Today, I removed the latch mechanism and sprayed some 'super lube' into the latch mechanism itself.. hoping this helps.
