First of all let me tell you guys that you're a bad influence on me. After reading all of the stories of how you have pimped out your stereos I could no longer resist the temptation and have ordered some stuff for my truck. I ordered the eclipse avn5500 navigation unit with the ipod adaptor, kenwood Excelon KAC-X20 amp and a kicker solobaric L5 dvc 10" (square) which is going into the jack compartment. I'm making a modified lid for it and am going to seal it with foil tape and foam before I fill it with poly-fill and bolt it down. I'm also going to run the power cable under the truck to the rubber grommet under the front passengers seat instead of going through the firewall. I'm also going to run the gps antenna wire out through it as well. I'm also going to use a lighted toggle switch for the amp power lead so I can cut it off when I need to. I plan on using one of the cutouts on the center console for that as well as placing the kenwood amp control in the little pocket next to it. I'm looking forward to getting this project underway and getting the bass back that I've been missing since I bought this truck.
