sudpuzzer-
I don't know if you already figured it out but you can access your stock amp under the passenger seat. You will need a special wire harness you can get from most car audio shops that has high output wires---to RCA plugs. All you need to do is splice into the stock amp harness and determine the +/- channels. Once you have the right wires spliced, the RCA's can plug right into the amp. Unfortunately the built in crossover for most amps is fairly weak and your using a high output frequency so another crossover or equalizer will give you optimum sound quality/control. Your stock deck will be able to control the bass still and it will sound great if hooked up right however if your looking for plastic shaking maximum output---get that extra device. I have pushed 2 JL W7's like this and the sound quality with the stock setup is top notch. Good luck and let me know if you need pics or something.
