There are two 8mm heads that adjust the vertical and horizontal movement.
Both are located on the rear of the housing, inside the engine bay.
The easiest one to find is under the black cover, this adjusts side to side movement.
The other is located down towards the fender, in the bottom corner. One direction moves it up , the other down.
Park the truck near a wall about 30 feet away and use a ratcheting wrench to adjust.
Good luck.
