On my 2001 Sequoia Limited 4WD I changed the rear rotors and pads today and now the brake warning light and VCS lights won't go out. :sad3d:
On each rear caliper when I installed the pads I removed the caliper from the brake line and when I reattached it after putting the new pads in I bled the caliper until the air was gone in the drain hose.
The pedal seems soft - do you think I need to bleed the front calipers to make the lights go out? Dot 3 is correct fluid right?
Thanks for your help...
