I was unable to find an 07 Tundra doublecab that had the equipment I wanted - and fog lights. In a thread in the Tundra forum, someone said they obtained the parts from Toyota to install the factory fogs and factory switch, but the parts came to $400 and the airbag, steering wheel, and part of the steering column had to be removed to install the new switch.
I would like to add aftermarket fog lights, in the bumper like the OEM, but with a separate switch on the dash. Most aftermarket fog kits require a fused relay (I would guess so do the OEMs).
Has anyone out there done this? Is there already wiring to the lamp locatons? Is there a relay? Already there? How can I identify the right wire going to the steering column (assuming that wiring is already there)?
Thanks in advance for any assistance.
