Hello
I bought a new stereo and I can’t install it for the life of me.
What do I need and how do I do it?!
Im about to take a bat to it and never worry about it again.
thanks
Go to crutchfield.com they have vehicle specific tutorial video. Also You tube has some great ones. I installed a new Boss double din unit with back up camera in my 2002 access cab with no real issues.
Basic access is there are phillips screws at the top of the air vents on each side of the center panel, pull off the three heater control knobs and you will find three more screws to remove. Then the panel will pull out. Be gentle and pop it out. Leave the heater control box in place and just let the whole panel hang down. Radio is held in place with four 10mm bolts.
As far as the wiring you will need to get a vehicle specific one that will make the wiring easier. ( Afterthought... to access those screws at the top of the air vents just tilt the louvers back.) Chap
