AIP Bypass for DIY folks available with Plates if needed.
2 reading
3K views 0 replies 1 participant last post by  slyfox75
#1 ·
Tundra Guys, I normally deal with the 4Runner guys over at T4r.org as that is the platform i run. But I wanted to let you guys that are DIY type folks that I sell the stainless blockoff plates for the bypasses if you decide to DIY vs the more expensive, yet very easy to install Hewitt Tech version.
I have the 4.6, 4.7 and 5.7 plates available for $40 for a pair.
You can contact me via T4R site as slyfox75 or via email at jeffcolemaps at gmail. (Im not on the forum everyday)
Just wanted you guys to know in case you needed a pre-made solution vs DIY and cutting your own plates.
I also have sell a simple premade solution for the bypasses.....but requires you to cut a wire. Not plug and play. But no special skills or tools required.
I ship out next morning after payment received.
Install takes about 10 mins. Instructions included. Simple install for mildly mechanically inclined folks.($48). They have been widely used on the 4R platform as well as the other V8 platforms(Seq, LX, GX, Tundra)
If you are slightly mechanically inclined the bypass is an easy install. If you have trouble replacing a light bulb:)(joking) I would highly recommend you go with the Hewitt-Tech setup as Paul has made it so simple to install.
-Jeff (slyfox75)
