** This post is very old. Please check out our website https://hewitt-tech.com for the latest and most up to date information.
We have Gen2 kits available now. Please check out our blogs for a comparison and explanations of the coverage and differences.
They are the most comprehensive and complete solutions available to date and far surpass all other kits in function and value.
hewitt-tech.com/blogs
Secondary Air Injection System Bypass Kits a Plug and play for 2005-2022 Toyota/Lexus Vehicles.
You can purchase your Original SAIS Bypass Kit Plug and Play or Wired Version directly from our website:
http://hewitt-tech.com
We can now cover almost every SAIS code with kit addons check out the codes page of our site to see what you need or contact us.
Give us a Call Toll Free 1-844-307-7671
Follow us on Facebook:
登录 Facebook
Subscribe to our Youtube Channel: https://www.youtube.com/playlist?list=PLb0PURtYjcMSdzgNiUueo8q4Sbqko84tq
Our V36 kits are available in Plug and Play and wired kits for the 05-07 vehicles and our V52 kits for the 2008 - 2012 and newer vehicles are plug and play only!
The V54 kits are here: Hewitt Technologies Inc - V52 Kits
OUR GEN 2 kits have been our for several years now and going back to update here!
We also have shop kits and special pricing for dealers (ask for details) as well as pump repacement packs and OBDII Tools!
We now have a pump replacement pack that will let you clear a P0418 or P0419 code after installing the bypass kit. They are especially beneficial if you have a 4.7L where the air induction pump is located underneath the intake manifold. No need to buy an expensive air pump and since they install at the pump driver(s) there is no need to remove the intake manifold!
You can now purchase directly from our website: http://hewitt-tech.com
Installation Instructions can now be directly downloaded from our Instructions Page
A failure of any component of the SAIS will generally set the check engine light (CEL) and cause the Engine Control Module (ECM)
to store trouble codes. Many of these mechanical failures will also cause the vehicle to enter “limp-mode” where throttle
response is limited to 50% to protect the engine from damage. Before installing the bypass module it is highly recommended to
address any codes not related to the SAIS. The codes below are the most common trouble codes that the bypass kit is able to let
you clear once the kit is installed and the codes are initially reset. Many of these codes can be caused by a failing SAIS Air Pump
which can also cause a loud vacuum cleaner noise for 20-30 seconds after a cold start. After the kit is installed the system is
prevented from operating and the below codes should not come back on, set the CEL or let the vehicle enter into “Limp Mode”
In general, the SAIS Bypass Kit cannot clear codes that are related to electrical faults or circuit malfunctions with the exceptions
of a few below and only under certain circumstances with the addition of a Pump Replacement Pack or a Pressure Sensor Jumper Harness to the bypass kit.
"Standard" codes the kits can usually take care of by themselves
P1441 - Switching Valve No.2 Stuck Open Bank 1
P1442 - Switching Valve No.2 Stuck Close Bank 1
P1444 - Switching Valve No.2 Stuck Open Bank 2
P1445 - Switching Valve No.2 Stuck Close Bank 2
P2440 - Switching Valve Stuck Open Bank 1
P2441 - Switching Valve Stuck Closed Bank 1
P2442 - Switching Valve Stuck Open Bank 2
P2443 - Switching Valve Stuck Closed Bank 2
P2445 - Pump Stuck OFF Bank 1* Important cold weather note
P2447 - Pump Stuck Off Bank 2
There is the occasional exception like a blown air pump fuse or damaged air pressure sensors.
Codes the kits can take care of with the addition of a Pressure Sensor Harness
P2431 - Air Flow / Pressure Sensor Circuit Range / Performance Bank1
P2432 - Air Flow / Pressure Sensor Circuit Low Bank 1
P2433 - Air Flow / Pressure Sensor Circuit High Bank 1
P2436 - Air Flow / Pressure Sensor Circuit Range / Performance Bank 2
P2437 - Air Flow / Pressure Sensor Circuit Low Bank 2
P2438 - Air Flow / Pressure Sensor Circuit High Bank 2
P106B - Pressure Sensor Correlation / Evap. Pressure Sensor
Only vehicles with two pressure sensors (one must be good) can take advantage of the Pressure Sensor Jumper Harness.
Codes the kits can take care of with the addition one or two Pump Replacement Packs
P0418 - Relay 'B' Circuit Malfunction
P0419 - Relay 'B' Circuit Malfunction
Usually caused by an open circuit/damaged air pump motor. One pack is needed for each code. Silver and Gold kits come with one.
Installing exhaust block off plates along with the bypass module is the only way to ensure the system is fully isolated and does not cause any future problems. The module can only prevent codes that are set because of leaking or stuck valves with block off plates installed. Sometimes valve trouble codes can be set by only a bad air pump but it is recommended that plates be installed if any codes for the valves are present. If you want to look at the installation instructions for more info or to get a better idea how to install the module and block off plates just send me an email and I will forward PDF copies for you.
Limited Lifetime Replacement Warranty and Expert Customer service and support!
Tried and Tested Unparalleled Reliability Designed In. Often Shipped Same Day.
How To Order:
1) If you have any questions about the bypass kit or your trouble codes please contact us through our website using the Contact Us page. You can also download the latest installation instructions from out Instructions page.
2)Go To
http://hewitt-tech.com. Select your vehicle and the engine/year from the drop down menu and checkout with a card or paypal.
Module Specs:
Compact Solid State Electronic Module (no mechanical or moving parts)
4cm x 4cm x 1.3cm Black Duroplastic High Temp Enclosure
3M Automotive Double Sided Tape for mounting
Epoxy Potted for environmental protection
Simple 5 wire hookup at the MAF/IAT sensor (wire diagram and vehicle wire color included in instructions)
18" 20awg TXL wire leads for easy connection.
Illustrated installation instructions
For off-road or racing use only.
Assembled by hand in the USA!
Just a few samples of my EBAY feedbacks, check out hundreds more here:
Ebay Feedback
Excellent Item!!! Exceeds my expectations and is well worth every penny!!! Buyer: Member id rip662
Awesome product. So simple to install and it works wonderfully. Buyer: Member id gwds69
Worked PERFECT!! Easy install. Thanks a million. (Or $2000 - $3000 saved) Buyer: Member id speedjunkie99
Absolutely amazing, fault code gone and passed emmissions. It's a great fix! Buyer: Member id jmckelveyjr
Exactly As Described! Great Price! Fast Shipping! Thanks! Buyer: Member id carsivservice
Hey everyone i purchased a module from pxsp and it works perfectly. The of it was way better than replacing the pump and a whole bunch easier. It's been on my truck for over a week now and have had no problems. If you have this problem with your truck you should definitely consider buying one from him.
My module came yesterday and installed it today. Worked perfectly - no code, no pump sound at first start up after setting for 24 hours. Thanks.
I installed my module this morning. It was so friking easy to do. Can't get easier then that pxsp
Thanks. I’ll let you guys know how it works in 1 or 2 weeks.
Over all, no surprises, and easy install.
I have put hundreds of miles on the truck and the CEL has stayed off. Saved $3100, plus I got a new scanner for future diagnosis . COULD NOT BE MORE PLEASED!!!!!
SAS Failure:
If you are not familiar with the Air Induction Pump Or Secondary Exhaust Valve problems on the Gen. 1a and Gen. 2 Tundras consider yourself lucky.
Although Toyota extended the warranty on the 2nd Gen tundras to cover replacement or repair of the system plenty of us have been shafted and stuck with only 2 options to remedy the problem: pay several thousand dollars to replace/repair the AIP secondary emission system or go to lengths to bypass and eliminate the system all together. The AIP system simply pumps air into the exhaust on startup to help get the catalytic converters up to operating temperature faster and thus improve emissions. It does not have any affect on performance unless the system fails. Two modes of failure are common. The air induction pump fails or the exhaust valves get stuck open or closed. I encountered a pump failure on my 05' Tundra DC XSP a couple of months ago, since it is not covered by warranty and the quote I received from my Toyota dealer was $3400 to replace the system I began working on an engineered solution to disable or bypass the system. Disconnecting the pump will disable the system but cause its own engine code. If your exhaust valves are stuck or leaking you will also need to install exhaust block off plates to prevent exhaust from flowing back into the system and causing "limp mode" even if the system is bypassed.
