Did search. Can somebody please give me a suggestion for air pressure on my ‘04 Tundra Access 4WD V8 with 265/70/17 BFG All Terrain K02 Load C tires on 17x8.5 rims? I’m getting them installed today and would like a suggested pressure to start with. I tend to wear the centers out of my Cooper AT3’s unless I run 32 front, 30 rear then it’s not too bad. Thanks in advance.
Super Moderator
Use the chalk method. That's the best way to dial it in for YOUR particular situation, load, etc.
It depends on YOUR situation. I start with sidewall max pressure, then reduce as dictated by ride quality or tire wear.
I run 42 in my BFG All Terrain K02 265/70/r16 LT on my 03 Access cap when not towing, gives a good ride on road and provides decent traction on gravel roads. Never have had a problem with wear, I’m on my 2nd set and get around 50k miles out of them.
Thank you. This is what I was looking for, just a starting point. I had to delay installation until tomorrow and now I’m not gonna have time to mess around with them for at least a couple weeks. Can I ask what your rim width is, stock 16x7 or something else? Are your tires C or E rated? Thanks.
