So much muddled information on the interwebs....hoping someone can answer this simple question. All these people wanting to lift their sequoia or simply swap out their airbags and it seems there is no concise answer. My question is simply this: WHY ISNT IT THIS SIMPLE?!
can I not do this:
153200
And then this:
153201
Or even this:
153202
Why is everybody cobbling together Frankenstein suspension parts, am I missing something?
2005 Toyota Sequoia Limited
I wasn't aware they were. It's very simple, either adjust the airbag sensor on the axle for height or swap your bags for coils. Pretty simple. Yes you can do that. Have to disco your compressor fuse as well
2005 Sequoia 4x4 Limited
What you wrote is pretty much as simple as it gets. Get the coil spring isolator/bump stops and new rear coil springs, and the conversion is done. All that remains is to disable the AHC system and install shocks suitable for use with the coil springs.
Thanks for chiming in XPLORx4, your input was actually what I was hoping for. I've spent the past week digging through forums looking for this information and I couldn't seem to find a cut and dried answer. I want to do a coil swap and a 3" lift, straight up, but all i could find information on was people piecing everything together and "wondering" if not hoping it would work. You seemed to be the one who had an idea on what was actually required to make the swap happen. So, back to brass tax, if I get the coil spring dampers, will the toy tec lift kit simply bolt-up as advertised with the specified lift height?
07firstgen-
I have an 05 with rear air suspension. I installed a 2.5" Toytec adjustable lift only on the front suspension. It's like the one you linked, but probably an older design. Rather than swap out the rear air bags with insulators and new coil springs, I kept the AHC and merely adjusted the height sensor to level the rear ride height even with the front. The benefit is that I didn't have to spend anything to lift the rear.
Of course, there have been several people here and on Facebook Sequoia discussion groups who have performed the full swap, which as I mentioned above is very straightforward. The spring seat on the axle is already compatible with standard coil springs, and since the air bags attach to the frame, you need only to replace the bags with the insulators in order to provide a place for the top of the new coil springs to seat securely.
I do not have first-hand experience with how much lift is attained using the Toytec rear springs, but since the front springs have adjustability, I imagine that it would be pretty easy to level it all out with the front adjusters only. BTW, get an alignment after you complete the lift.
I'm sure there are several ways to disable the AHC, but I haven't specifically looked into which method is the most desirable to disable it, since I intend to keep my fully functional AHC system for now. The airbags are only 4 years new, with fewer than 70K miles on them, and the feature is frequently put into use when I tow. I do not plan to do frequent severe off-roading that will require extreme axle flex that is possible after installing taller springs and shocks and removing the rear sway bar. For the occasional times when a rear tire lifts due to insufficient axle travel, I have a rear ARB locker to help put power on the ground. My Sequoia is built as more of an expedition vehicle rather than a rock-crawler. My other 4x4 is built up for that purpose.
I hope that helps.
