1 - 10 of 10 Posts
· Premium Member
4 Wheel Parts on the South Loop near Almeda did mine. A tad pricy but everything is working great. I would also use Tejas Toyota but only if Floyd Greer does it.
Dan
I ran into the same prob due to my 24's. I called every 4wheel parts. Aron at 4WP on 610 refered me to southwest Houston Tire Sales on Bissonnet. Not the most high tech/clean place but the guys did a good job. Mine is lifted and is harder to do and still did well! May want to call to see if they can do 26's. 713-664-7731. Good Luck.
BTW do you know anyone that wants some 24's?
I'm getting outside tire wear with my 5100 shocks set at 2.5 lift.
What were your final lift specs to give me an idea, camber , caster, toe etc.
my camber is .5 degrees both sides, toe is like .16 degrees both and caster is like 3 degrees both sides.
Wondering cause don't want to wear out new set of 275 65/18 AT/2'S.
Everyone says to rotate often, but wear was even without lift shocks.
TRD DUNN I P.M. you to give me IDEA.
Auto Line Of America
839 Center St. Deer Park Tx.
281-476-4092
About 20-30 people in our offroad club have been going to them for bout 8+ yrs. They have been the only ones that have been able to truely align alot of our vehicles. They are able to align the vehicles that we have cut off the iFS and put SAS on. They give you 1 free alignment (warrenty) within a year. We beat the hell out of our offroad truck and with big tires everyone has tried other place and we steer them to Auto Line after no one else can get it right, but Auto Line is able to align.
I would give them a try.
Ask for Ted the owner and let him know Manny, Shannon or TTORA sent you he'll know who we are.
Manny
Now that's what i'm talking about evol, this is the kind of place that "gets" it. They probably use the machine to get them close then go with what's in their heads, may be worth a shot!
You may be right,
I AM CONSIDERING DROPPING THE HEIGHT OF MY 5100 SHOCKS EVEN though I love the ride, level look and shocks are good. I am a street guy but don't like seeing my tires wear after 3000 miles on outside where in 10,000 miles it will be really obvious.
I live in PEARLAND AND work in Sugar Land, NTB aligns it the best way they can and so dod ALLOUTOFFROAD the installers of shocks that deal in 4x4. Took it back to them first when first seeing it and told to rotate often. :confused:
Called and went today for alignment to TED'S. HE ZEROED THE CAMBER TO REDUCE OUTSIDE TIRE WEAR BUT HE TOLD ME that some of the adjustments are maxed out.
Thanks MANNY, WE will see how this works out.
281-476-4092
Manny
1 - 10 of 10 Posts
