Supporting Vendor
Whether you are replacing damaged lights, or want to refresh the look of your truck, aftermarket headlights are something that you should definitely consider. Alpha Owls is a premium manufacturer of high-quality headlights that will illuminate the darkest of the night while enhancing the aesthetic appeal of your Toyota Tundra.
Their headlights are designed to give your truck the most aggressive style possible without compromising on the brightness. They use high-quality LEDs and advanced projector technology to produce powerful illumination that’s easy on the eye.
Alpha Owls® - Quad-Pro Black DRL Bar Projector LED Headlights with Sequential Turn Signal
*Fit 2014-2019 Toyota Tundra
*Fit 2007-2013 Toyota Tundra
Features:
  • Designed to only replace OEM factory style headlights
  • Ideal solution to both enhance your visibility and make your vehicle more visible
  • Made using innovative LED technology to ensure excellent light output
  • Sequential turn signal feature to inform others of your intentions
  • Unique design to give your vehicle a more stylish look
  • Guaranteed to offer long-lasting service life
Take your Tundra to the next level of style and lighting performance with Alpha Owls headlights!​
Supporting Vendor
Discussion Starter #2
Make this spring brighter with a new set of lights from Alpha Owls! Shop now for top-quality Alpha Owls lighting products at CARiD and save 5% OFF! Enhance your visibility while adding custom style to your truck with Alpha Owls. The offer is valid through April 30, 2020. Prices are already reduced.
Alpha Owls™ | Automotive Headlights — CARiD.com
