In 2wd, you can press the Trac button and get the ALSD light to engage, which in my experience makes the ALSD function far more aggressive.
In 4wd, you cannot get that light to engage. Does the ALSD work in 4wd, or is it 2wd only? Is it always on, or if you turn Trac or VSC off, does the ALSD also turn off in 4wd?
4x4 and A-LSD are mutually exclusive. Before you tap the button to illuminate A-LSD, the A-LSD does not function at all. The "less aggressive" measure you're experiencing is just traction control. If you want to change Trac/A-LSD/VSC settings, you must do it in 4x2 mode, then switch to 4x4.
