I got a used amp and when i hooked it up, every time the power reaches the amp, the fuse blows....what causes that...is there anything i can do or am i screwed
what amp? Do you have another amp to throw in to test the integrity of the power hook-up? But yes you might be screwed.
If the fuse blows as soon as you hook up the amp, then the amp is fried. You could try taking it apart and fixing it if you are electronically inclined.
the ground is behind my seat on the back wall....i think its just screwed becasue when i hook my old one up, everything works fine
