So I've been reading a lot of the posts regarding Tundra/Sequoia wheel alignment & stability issues and pulling even after an alignment - basically, for the same reasons many reading this did.
But first, special thanks DJ for all the helpful information provided on this and other forums.
My 2012 Sequoia had a hard pull to the right and I found myself constantly fighting the steering wheel to keep her on the road. She was fine when I bought it with 80,000 miles then the ex had it for 30,000 miles and when it came back to me the truck pulled hard and had worn down a set of cheap tires within 10,000 miles.
Even after 2 alignments (result attached) I am still dealing with a pull and continuously having to correct the wheel to keep her on the road. Now that I am getting new tires it MUST be resolved. For simplicity, I've typed out the before/after settings from the attached.
Date Camber Caster Toe
LF RF LF RF LF RF
Specs 0 +/- 0.8 3.75 +/- 0.75 0.1 +/- 0.04
2/25/21 Before -0.1 0.0 - - .35 -.19
2/25/21 After -0.4 0.3 - - .1 .07
3/17/21 Before -0.4 0.1 2.8 3.2 .05 .09
3/17/21 After -0.4 0.1 2.8 3.2 .09 .07
The "-" indicates no measurement taken/provided.
I read through DJs recommendations and I will go to the Firestone and request they set her as close to 0 for Camber, 0.1 for Toe, and 4.5 on the Caster. It seems rather high, but heck DJ is the expert. Clearly the shops setting the Caster at the low end of the range is NOT working.
LF RF LF RF LF RF
