I posted this is the Tires and Wheels section over a week ago, and not one responce... Thought I would check here.
Anyone running 265/75R16 BFG AT K/O's on a 2006 Tundra DC TRD 4x4? I searched and read a lot of posts... Some say they rub and others say they dont. Any help would be appreciated. The stock tire 265/70R16 BFG tire is almost 25 bucks more a tire...
You should be fine. I've put that tire on many a Tundra. That being said the reason you are getting different stories about rubbing is because of the varying definition of "rubbing." Could the wider tire could possibly make contact with the plastic inner fender well cover on full crank and suspension compression? Possibly. Will this cause any problems? No.
You should be fine. remember to post some pics for us.
I have that set-up on my 06 DC 4x4 O/R TRD. I had the Hell-Bent Steel leveling kit before the tires, but in 35k+ miles never any rubbing. It is a little close to UCA for my liking as HD chains would rub there. But overall great tire for this truck.
