1 - 9 of 9 Posts
Hi All,
I have recently obtained a 2004 Limited Tundra Access Cab- which I love but the arm rest seems to be broken (or maybe just loose?). It's limp and does not stay up where your arm would normally rest. Anyone know the best way to get this fixed? I've looked around pretty thoroughly on the web and don't see the part readily available. Thanks in advance for your help.
Either buy new bucket seats with five point harnesses, or work your arms out so you don't have to rely on a piece of fabric and plastic to keep your arms at 90* at all times.
Resident Curmudgeon
What do you mean by fried?
I mean that you can see several spots along the seam where the teeth are, for whatever reason, mangled. I was able to pull the seam apart by prying open a couple teeth and then found out the only problem was the metal bolt was loose! I tightened the bolt, pulled the leather over the broken zipper which fortunately covers it. Thank God for that as I just called my local dealer and that arm rest is $341!!!! Thanks all for your help!
1 - 9 of 9 Posts
