"Auto" Climate Control Default
1 reading
5.5K views 8 replies 8 participants last post by  carnutz
#1 ·
I have a 2004 Highlander Limited with the Navigation system so that the climate control system is through the touch screen.
I have noticed that whenever I hit the "Auto" button to have the system automatically control the environment, it always turns on the A/C.
It's been chilly outside where the outside temp is 20+ degrees cooler than what I set the inside temperature for.
Am I always going to have to manually override the default to turn the A/C on everytime I use the "Auto" button?
The Toyota Manuals do not discuss this issue.
#7 ·
gman said:
I have the same issue in my car, but it seems as though it says "air conditioner," but it is really throwing out heat at the climate temp you set manually - 74 degrees, etc...
I have found that it simply uses the words air conditioner for everything, even if it is the heat.
I don't pay any attention to the fact that it says "air conditioner". It's the fact that the light over the air conditioner button stays on and it runs the compressor.
It will even run this in cold weather because in order to defrost the windshield, etc., you want the compressor on.
#8 ·
My 2005 Sequoia and my 2003 Highlander both do the same thing when AUTO is pushed it is annoying to push the A/C button to turn it off everytime. I would leave it on but knowing the A/C compresser is on just bothers me because you loose a little Horsepower and GAS. In the winter I just hit the AUTO button then turn off the A/C and if you turn your truck off like this you won't have to do it again it remember's the last setting. (work's well with Auto Start) John
#9 ·
All modern automotive HVAC systems use the same duct work for the heater and A/C. When you use the automatic climate control, the A/C compressor comes on to remove any moisture in the air and then it passes over the heater coils where the air is heated to the temperature you have dialed in. The dry air is blown into the interior where the moisture is absorbed and that air is either recycled or dumped outside. It is not very efficient to run the compressor in the winter, but the windows do not fog up as much when it is running.
