Needed to find an ideal spot for a set of auxiliary switches in my Tundra without major alterations of the dash. Decided on the empty spot below the ignition key area. Modded a few metal brackets to the removable lower dash panel. The switches are easily accessible and look custom. Relay box +circuit breaker + fused mounted in the engine compartment provides 12V power to any lights or accessories with a simple hookup. Just wanted to share the end results.
Discussion Starter #2
Relay box mounts under the hood. Only one wrapped cable enters the truck. Future accessories tap fused 12V power with separate relays and protected with a circuit breaker
