I've been searching and reading through a lot of posts about mileage with both the 4.6L V8 and the 5.7L V8. A lot of reports on here about people averaging 17 to 21 mpg in mixed city/hwy had me worried that my new 2013 4.6L CrewMax 4x2 had some issues. I'm only seeing about 15 to 16 mpg in 70% city/30% highyway. The worst was my first tank which I got 14.3 mpg and my best was 19.2 (mostly steady at 70 mph). So obviously I was thinking what do I do? Tried inflating tires from 32 to 40 psi... saw maybe .5 mpg improvement and the ride quality suffered (found that 36 psi was a happy compromise). Then I looked at people doing the hydrocarbon filter removal mod and read and read.... and read.... and read. Then turns out you can get the same temporary results simply by disconnecting the battery terminal for 10 to 30 minutes and resetting your presets on the radio and leaving the filters in place(LOL). I'm still waiting to hear if anyone had REVERSE results when REPLACING the HC filter. Sounds hokey.
Anyway, back to topic... I was worried that I wasn't seeing what others were seeing in terms of fuel efficiency. Then I did a little research outside of this forum; namely on fuelly. On fuelly, I first found all of the postings for Tundras that specified they had the 4.6L V8 in the description and averaged those average mileage figures. Then for kicks, I did the same for the 5.7L V8. Wow, I am NOT calling anyone liars on here, but I'm seeing something wildly different in those averages than the averages people are reporting on here.
Average on fuelly for the 4.6: 15.96 MPG. (with single highest and single lowest values removed: adjusted value is 15.76 mpg)
Average on fuelly for the 5.7: 15.35 MPG. (with single highest and single lowest values removed: adjusted value is 15.45 mpg)
Where's the 17's, 18's, the 21's?????? Lucy... you got some 'splainin' to do!
Rant begins here:
Oh and HOLY CRAP: When anyone asks questions on here about anything specifically relating to the 4.6L V8, why does everyone come out of the wood work to start going on about the 5.7L??? I understand that the 5.7L has +80% of Tundra sales, but what does that have to do with the 4.6L? That'd be no different than someone asking about a Camry hybrid on the Camry forums and all the Camry V6 owners chiming in on how the hybrid compares to the V6. They are simply two different engines. It makes searching for information MUCH more difficult when you have to rifle through all the stuff that doesn't apply. Also, how does the phrase "should've gotten the 5.7" help anyone's case? For some, the 4.6L is perfect. I'm one of those people. I want enough power to make passing easy. Period. I don't haul anything. I don't tow anything. I only need a truck for those 3 or 4 times out of the year when nothing else will do the job of a truck. My testosterone says "MUST DRIVE TRUCK OR SPORTS CAR". Having a family means that the sports car is O-U-T. So Tundra it is! I love my CREWMAX with the FOUR POINT SIX LITER VEE EIGHT.
:doh::facepalm:
Respect and thanks!
Rant begins here:
:doh::facepalm:
Respect and thanks!
