The stock Geen Eye started going weak after 5+ years in the 2006 SR5 Dbl Cab w/ tow package.
Checked the charging system, all seems well enough so I'm taking the plunge and swapping in a Diehard Platinum P1 instead of the P5.
The stock cabling isn't long enough with the reversed terminals and the stock mounting bracket will need some adjustment.
My question, for those that have done this or even those that have done the dual battery upgrade, did you just extend the cables by bolting on some 1ft extensions, going with a standard battery terminal and bolting the pigtail to the stock wiring after removing those nifty Toyota battery terminal clamps. Or did you really get in there and retire completely back to the fuse box and replace the ground cable entirely.
Obviously I'm hoping that folks used something like the 4 gauge 15" Coleman cable from Sears.
Sears: Online department store featuring appliances, tools, fitness equipment and more
