Does anyone know who makes a bed cover for the 07 tundra. I want a roll up type, but not vinyl to much maintanence. Any input would be great.
I also have a bakflip on order which is due next Tues. It is my understanding that the rails of the bakflip attach to the multi-track rail system, making them useless for using the sliding tiedowns. Is this the same rail system that you are talking about? It does not matter to me that it makes the rails not usable because like you stated I would use the D-ring tie downs. The rail system was the only accessory that came on the truck that I would not have ordered if I had it to do over.The only issue I am not certain about is whether I will need to remove the deck rails to install it. I am fairly certain that I can avoid this by using alternate clamps but if I have to remove the rails then I won't mind too much - the bed has 4 D-ring tie down spots anyway and these were all I ever needed in the Tacoma.
Based on everything I have read and the installation video on the BAKflip site, it seems almost certain that the Toyota factory deck rails will need to be removed to install the BAKflip cover rails. I think the primary reason is that the BAKflip "C" clamps are designed to sit directly under the bed lips which is exactly where the Toyota factory deck rails are mounted.I also have a bakflip on order which is due next Tues. It is my understanding that the rails of the bakflip attach to the multi-track rail system, making them useless for using the sliding tiedowns. Is this the same rail system that you are talking about?
Good point. I really hope to work around it and leave the rails on even if I have to modify them. If not then I guess I would plug the holes with the original factory bolts - perfect fit plus I won't lose them if I need them later.My concern is plugging the holes that are left when you take the rails off. I am thinking that I could get little plastic plugs from Lowes or Home Depot.
This is true about the factory holes. My Access cover was delayed again but is supposed to ship next week.Good point. I really hope to work around it and leave the rails on even if I have to modify them. If not then I guess I would plug the holes with the original factory bolts - perfect fit plus I won't lose them if I need them later.Also, with a waterproof bed cover on most of the time I am not worried about a few small holes in the side bed walls. There are actually at least two unused and fairly large holes from the factory anyway.
The BAKflip manufacturer states that the factory deck rails on similar vehicles have to be removed or remounted an inch or so lower than normal in order to make room for the cover rails and clamps.
Thanks for the link. The info I had been looking at was on "bakliner.com" but the info you found is on "bakfliptonneaucover.com" and it is different. They appear to be the same manufacturer and product so I wonder why they have different websites with different info? I do hope that the cover comes with the custom bolts that slide into the deck rail system - that would make it even easier and quicker to install or remove at any time. The only possible problem is that the cover rails might block some or all of the deck rail and if so then you can't use the deck rails for tie down cleats. If this is the case then I would prefer to use the clamp method so I could work around it with special clamps and still use my deck rails. I will post detailed pics of the install process after it arrives. Hope to have the product here and installed within the week.If you look at the info and pictures at the Bak website and go to the Tacoma+05 and Tundra 07 information, it looks to me that the rails from bakflip mount to the exsiting rails.
Excellent! :tu:IF you look at the info and pictures at the Bak website and go to the Tacoma+05 and Tundra 07 information, it looks to me that the rails from bakflip mount to the exsiting rails. It states "The covers have specially made hardware that fits directly into the the Deck Rail System without any modifications to your truck."
"BakFlip Tonneau Cover - Installation
I would be interested in what you come up with. Please post and let us know what you come up with once you get yours installed.
Wileetundra,I will post detailed pics of the install process after it arrives. Hope to have the product here and installed within the week.
koahokuIt looks perfect!!!The only thing though it looks like it uses the deck rail system so when you put on the cover the locking chanel is blocked,is this true?
