Does anyone know if I can install a bed rug
while I have a roll n lock and factory bed rails installed already.
Minus the front rail of course or does it all have to come out first?
thanks in advance
triplejjj
Unless something has changed with newer models, should not be a problem. The bedrug
fits under the rails all the way around, so, you should be good. Only issue I can see is how the cover is installed and how close any clamps may be to the inner bed walls.
The bedrug is flexible for install, so, should fit okay, without removing anything.
I have the bedrug on board, and it fits nicely with my ARE cover. Bed caps are on top, so, that is not a problem either. (I do not have bed rail caps with my setup).
Pics in gallery for reference.
