whats up guys, i know theres prob tons of talk about whats the best lift kits and stuff for a 2001 tundra access cab, 2wd v8, i wanna go kinda pre runner/dessert runner with it, ya know, lower in the *** with one of thoes "chin strap" brush guards with the skid plate and lights in the front, let me know what yall have found, and pics would be great!
thanks
If Your Going for Prerunner Go For the Camberg Long Tavel Kit. Its Pretty Damn Sweet and Stage 2 Gets You Like 13 inches of travel. But also requires fiberglass wide fenders or cut them open more. Or go extreme for 20 inches of travel.
T
Guest
If you want to go pre-runner, just lift the front and leave the rear alone. Usually going with a full coil over is the way to go. Give's you better ride quality, and a small bit more travel than your stock suspension. Good luck deciding.
If you plan to long travel the front...5k, plan on sinking another 3k in the rear depending on bed cage & bipass shocks...and that is just for a SUA set up. If you don't do the rear you will have wasted 5k on the front for nothing, it won't keep up.
...or just run a c/o & uca in the front, and a Deaver g57 pack with a well valved 2.5 shock. roughly 3k or so for everything.
