Hi,
Just purchased a new set of BFGs A/T 265/70/17 for my 2005 DC Tundra 4x4 SR5 and was wondering as to what psi I should set them at in order to get the best results for wear, ride comfort, etc.....
Also, any of you own these, if so, how do you like them?
Cheers
Joey
Mech. Engr. / Mechanic
If you get 10 responses, you'll get 10 different opinions. Tire pressure has been discussed on here many times. You'll find answers from 28 psi to 40 psi.
It all depends on you. How much does your truck weigh as you drive it daily? To a point, you sacrifice mileage for comfort.
Do a search for tire pressure on this forum and you'll get more info than you can digest.
Good luck. I run 35 in the rear and 32 in the front.
single's right. I tow a lot, so i'm running 44 psi all around on my BFG K/O's. As far as do i like the tire? Put it this way- every truck/suv I own is running the same tire :)
