How do I tell if I have the smaller calipers?If you still have the smaller calipers the best thing to do is simply upgrade to the larger ones. http://www.tundrasolutions.com/forums/brakes/65633-upgrade-your-early-tundra-brakes-1-a/
There are some larger brake kit made by the aftermarket but most require a wheel change and they are basically racing brakes which seem to last forever on the street but can be extremely expensive to maintain.
Mike
I suppose that is one way to look at it.If you never had the brake TSB done to your truck, then you still have the smaller calipers.
Rick
Well, I definately have the old calipers....Look in the TSB section for this TSB
BR001-03 FRONT BRAKE COMPONENT IDENTIFICATION (REVISED)
There is a picture of both the old and new calipers side by side. You should be able to tell which you have after comparing your calipers to the ones in the pictures.
Rick
