Stock coils are fine. Alignment specs attached.
so if i have a 3" leveling kit already installed on the front of my truck i would need to have it removed before i install the 5100's on the front?
kinda new to lifts/suspension etc
what does a diff drop do and will i need to do this as well to mine?
Good point. I never thought to ask if it was 4WD. If your truck is 2 wheel drive, you wouldn't need the diff drop.Is your truck 4x4? If so then I would definitely put the diff drop on.
