OK, well, I've kind of come to the conclusion that the difference in price for tires to have a 33" size with an "E" load range than to get them with an "E" load range from a place that I trust to install them correctly is more than enough to get the lift that the latter tires would require (since they would be 34").
I'm just not sure which route to go and would like to hear some opinions. I can go with Bilsteins on all 4 wheels and get 1" or 1.5" blocks for the rear and lift the front 2.5" or so, or I can get a 3" lift kit with the spacers on the stock shocks/springs. There is only about $100 price difference between the two... any suggestions on which is better? Would the Bilsteins with the "E" rated tire constitute too stiff a ride? Are the stock shocks/springs good enough? Is using a 3" spacer up front going to cause me more damage to the truck later on?
