I talked to one of the guys at BMF, and he told me they're only working on the 8 lug for now. However, if there is enough interest, they could possibly speed up the process on the 5 lug. The bad news is, they're only making it in a 12" wide wheel, because nobody else is doing that. I hope that works out for them, but I'd much rather see a 20 x 9, 5 on 150 with a +30(ish)mm offset. What do you guys think?
Haha...I guess they only plan on selling that wheel in Hawaii.Ive seen a few island trucks that have that style on huge lifts,20'' by as wide of wheel they can shove underneath.
It must take the CNC programmer about 20 minutes to set up a 5 x 150 bolt pattern. then a few minutes to set the proper backspacing and let the machine produce a wheel to check clearance, then make 3 more and test.
12" wide wheels would be good for those wanting to run 305 or wider tires.
I asked them the same thing a couple weeks ago (20x9 30ish offset) - he just referred me to the other three options they offer for 5x150 and told me to suck it. I'm buying some XD's even though they are played out.
cause they're badass ;)
