41 - 46 of 46 Posts
Driver of 2 Tundra trucks
Discussion Starter #42 (Edited)
The BAMuffler exhaust combined with the DAP tune and some premium fuel has made this truck quite the performer, it's about to hit 290,000 miles and it just loves to rev & run.
I removed the negative connection to the battery for 90 minutes to re-flash the computer so it could re-learn the improved exhaust flow.
Discussion Starter #43 (Edited)
Lowering the rear involved the suspension, but it doesn't actually lower the suspension... the rear axle is the same distance above the road as it was when it left the factory. I didn't make any changes to the the front except replace the coils with fresh factory coils, it sits at factory height.
From a visual perspective, this mod eliminates the jacked up rear end / empty vintage moonshine runner look associated with RCSB Tundra trucks.
150889
150890
Discussion Starter #44
I have owned this old truck for just over 2 years, and I have enjoyed the entire process of making it mine. Looking toward the future... I am considering installing the smallest diameter ARH direct connect headers with cats and the Auburn Pro LSD. And as much as I like the TOYO tires, I am kicking around the idea of replacing them with Michelin performance tires that are slightly taller than stock. Michelin tires just ride better. Other than that, I will continue to clean up the vehicles interior & exterior appearance while racking up more miles.
150905
Discussion Starter #45 (Edited)
2020 began with 290,439 miles on the odometer.
I have fine tuned my future plans for this truck.
Appearance:
I plan to have a Super White bumper & grille up front at some point. Other than that I will continue to clean the exterior, touching up rock chips & scratches as I go, and I will probably have the PDR guy go over the body again.
Tires:
33" Michelin Defender 275/70R18 LTX M/S to replace the current set of used Michelins on the white wheels. I will continue to run the TOYO's on bright alloys during the summer months.
Performance:
ARH Direct Connect long tube headers exiting the current BAMuffer cat-back and single tail pipe. I have put the Auburn LSD on the back burner.
This is how it looks right now.
151113
41 - 46 of 46 Posts
