avs bug deflector II for '10 cm, has any1 figured out how to pop out plastic piece to install shield any info would be great instructions are vague and not helpful :beavbutt:
I just installed mine and wish I hadn't. First of all, that plastic piece of trim they tell you to pop off to access bolts underneath.... there are no bolts underneath. You need to take off all the bolts on the inside of the hood, then use that plastic paddle to pry the plastic grille surround trim piece loose. In the process, you are almost sure to break a few clips. Then the ends that curl under the hood and are held in with clips don't fit right and will scratch the finish off the plastic grille surround.
I now have 2 broken clips and gouges in my plastic grille surround, so I can't take it off and return it. I was not happy with how it fit on my 2010...
