I added 33's with -12 offset Motiv rims with a 3" lift to my '11 Sequoia. Looks great, but I didn't consider how far out the tires will be. I live on gravel roads, so after just a day, I put my stock rims/tires back on. I won't have any paint left by the end of the week if I keep the 33's.
Until I can find a solution - either less of an offset, or fender flares - or a combination of both, I cannot enjoy the larger tires.
Just a follow up post for anyone who may stumble across this thread. Thanks to @Farnsrocket, I finally determined what went wrong with my build. The stock rims are a +60 offset. I was working under the false pretense that the stock rims were +30 and never verified.
So when I ordered the -12 offset, I thought I was moving the center of the rim out by 42mm. The reality is, I moved it 72mm. That's why I'm seeing the tire nearly 4" further out that the stock rims:
However, if I was to replace the -12 offset with a +40 offset rim, not only would the inside sidewall of the tire be in essentially the same spot as the stock tire on the stock rim, but the outside sidewall would only be roughly 1.5" out further than the original:
Now to find a place to get a 20" x 10 rim with a +40 offset that looks halfway decent, that won't cost a king's ransom. On the upside, I was able to source some pocket fender flares for my 07 Tundra, so if those work ok, I may put these -12 offset Motiv rims on it.
21 - 24 of 24 Posts
