My 2002 tundra SR5 is leaking into the cabin from somewhere. I had satellite radio put in a few years ago by best by and trying to be safe and wanting to keep the warranty with it I had them do it. This is where I suspected the leak to be coming from so I took it back and they said the warranty is expired. So I went ahead and spent the 8 bucks on a tube a silicon and went resealed the third brake light and the smell and evidently the leak is still somewhere. The other threads all involved actual water leaking onto the floor so I do not think they are related. Also the rear window does sometimes get a little musty. Any other possibilities beside taking the back window out and resealing the whole thing??
Not sure if this will work but this is where I would begin. Start the truck with all the windows up and the blower running full blast. Take a spray bottle with water and a little liquid soap and spray along every seal, crack, crevice and anywhere else two parts come together and look for bubbling to find the source of the leak.
that makes sense, i would also suggest turning off the recirculate to try and build some pressure
When my system was put in they needed to run a cable from the battery into the cab...there is a grommet on the fire wall that they screwed up and i h ad to replace it...you might want to look there.
Yes, I agree - the recirculation should be set to fresh air in order to build pressure.
Resident Curmudgeon
Cowl blockage / leak?
