Hi all. My 2014 tundras acting up again. Started it up today and was greeted with a check engine light code is for a camshaft position sensor b circuit high input bank 1. This issue came up after swapping back to my original ecu, I had a replacement ecu fitted to try to solve my pedal issue which didn't work. On the replacement ecu I was getting a code for p0353 for a coil I swapped a coil and it still remained the same. I ended up going back to the original ecu and am stuck with this code
