The '07 plays audio and video DVDs only from the overhead DVD player, just like in previous years. My '05 DC with rear seat DVD will play AUDIO DVDs. No video up front without a 'Lockpick' from Coastal Tech.
Rich
You still need the Rear Seat DVD Player. The factory NAV does not include a DVD decoder. The only way to watch dvd movies on the front screen is if you have the rear screen/dvd option and have the parking brake on and not moving.Even with the parkbreak on and the transmission in Park - I can't get any DVD play.
Yes. You can even watch it while driving as long as you ground the parking brake wire and install a switch on a speed sensor wire. Your NAV will still work (via GPS reception) but it won't be as accurate since it doesn't have speed/dead reckoning input when you have the speed wire bypassed. Don't know if port installed DVD will work, I can only confirm that factory installed ones (i.e. only in the Crewmax) do.Wow. You learn something new every day here. So you can watch an entertainment DVD in the front on the NAV while in park? Dual-screen it with those in the back? Very cool. Does this work with the factory DVD player only? For example, the port-installed DVD player is different from the factory DVD player in the Gulf States and South East regions.
They do not have anything for Tundra. I watch them for the last 2 month and nothing yet.Prius Accessories
The lockpick does a lot more than enable the dvd. You might want to check them out.
Rich
I know that, the NAV after that is working with some delays.zpaul, you might want to hit up that guy wiletundra. His site shows that he'll make that lockpick for you for a very reasonable price.
