I recently was involed in an accident causing my rear end to be slanted to one side the leaf sprngs broke and shocks and carrier bearing. replaced everything with new parts and deicided to put 5100 shocks on front and rear. i dont have blocks or AAL in the rear yet but my problem is after replacing everything and haveing a new bearing put on the drive shaft the bearing is off about 2 1/2 inches forward from the mounting point. Any ideas?
Make sure your carrier bearing isnt for a 2wd tundra. either that or its installed in reverse. the carrier bearing is attached the the front half of the driveshaft (before middle u joint) so i cant see how a rear end being tweaked would mess with that.
Thanks for the advise but took a look at again this morning in the day light and saw that the mounting bracket was bent back it looked factory but after seeing a pic of someone else I just took a hammer and bent it back and good to go thank for the fast response though
